Author Topic: anyone know stock ride height of gti?  (Read 3320 times)
Offline antonis
« on: 12 December 2012, 09:13 »
as title, does anyone know the stock gti ride height?
I believe ground clearance is 14.3cm.
How high is it measured from road surface to fender?
thanks
Offline antonis
Re: anyone know stock ride height of gti?
« Reply #1 on: 12 December 2012, 09:43 »
do these seem right?
Wheel Center to Fender Measurements:
MkV Non-US GTI: 360mm/365mm
Offline ROH ECHT
  • K04 PLAY...ZUMDIS!
« Reply #2 on: 28 December 2012, 04:17 »
US MKV GTI's, post 2008.5, are 26.4 inches from the ground, through the center of the wheel, to the top of the fender arch. The lowest lowering springs (h&r supersport and eibach sportline) should drop that to 25.0 inches +/- 1/8 inch. Other type springs (h&r race or eibach proline) will be 1/2 inch higher than these and have a stiffer spring rate. I do not have pics of stock but sportlines sit good;
H&R sport-cup kit will sit a bit lower as do my new H&R SS's;
« Last Edit: 28 December 2012, 04:23 by ROH ECHT »
`07 GTI/AWE K04 KIT/APR HPFP/S3 INJ./EURO S3&FORGE FMIC's/TECHTONICS TUNING TURBO-BACK/BSH PCV/AWE DV/NSP VENT BOOST GAUGE/BSH MOUNT's/NEUSPEED INTAKE&THROTTLE BODY/GIAC K04 H/O & DSG FILES/ECS ST3 BBK/ECS REAR DISCS (D&S), SB LINES/H&R SS SPRINGS, & 24mm ARB/BILSTEIN DAMPERS/TSW NURBURGRING's>1/4 mile: 12.82 @ 112 mph
