Author Topic: oil temperature gauge  (Read 1227 times)
Offline Scott D
« on: 12 December 2012, 00:11 »
has anyone fitted an oil temp gauge specifically a newsouth gauge and sender?
from what I gather there is a 10" blanking plug on the oil filter housing that can be used but will the sender unit fit or is a sandwich plate required?
cheers
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: oil temperature gauge
« Reply #1 on: 12 December 2012, 06:49 »
I don't think the probe will fit in there. Just run it from the sump plug via an adapter like I have
« Reply #2 on: 12 December 2012, 09:56 »
Oil temp probe will not fit the spare port on the filter housing as it is not deep enough, oil pressure will fit however.
Best option as Wazzer said is to run an adaptor on the sump plug.
Offline wotavudunn
« Reply #3 on: 12 December 2012, 10:06 »
what ever you do, DO NOT fit a newsouth oil pressure gauge. the quality of the sensors are very poor and snap in the oil filter housing.
Offline Scott D
« Reply #4 on: 12 December 2012, 23:42 »
I'll give the newsouth a miss then, would expect quality considering how much they cost.
Will have a look for an adaptor.
« Reply #5 on: 12 December 2012, 23:57 »
Well worth trying: http://rspec.co.uk/
Offline Scott D
« Reply #6 on: 13 December 2012, 00:38 »
Had been looking on ebay but found everything on there :) cheers Wayne
Xmas shopping has begun lol
