Author Topic: Oops!  (Read 835 times)
Offline GTi_James
Oops!
« on: 11 December 2012, 17:34 »
right lads,
just finished work, decided to get home a bit faster than required so with a bit of spirited driving down an old straight A road i heard a pop and slight loss of power  :lipsrsealed:
pulled up home and noticed that idle was a bit funny and theres a click when hard over right and the going back to straight  :undecided:
popped the bonnet and saw a bit of moisture on the side of my can so stuck my hand down the side and the friggin drain plug has shot off the side of my can, dented my battery harness plastic and is now sitting somewhere on the old A12  :angry:
questio: is it ok top drive about without the plug until a new one is sourced and can anyone tell me when happened to my idle? its almost like its hunting for normal idle and i think with the cold weather and not using my vehicle for 12 hours my exhaust has given the ghost, would this cause the problem with idle as well?
Offline Dalo Harkin
Re: Oops!
« Reply #1 on: 11 December 2012, 18:25 »
how long has the catch can been in?
sounds like too much pressure build up as in the wrong plumbing of the hoses into the can..............
Offline GTi_James
Re: Oops!
« Reply #2 on: 11 December 2012, 18:40 »
been in since July, had a mechanic help me with the can too so was correctly plumbed, have emptied it 3 times no issues  :undecided:
Offline Dalo Harkin
Re: Oops!
« Reply #3 on: 12 December 2012, 12:07 »
There shouldnt be a pressure build up to the extend to blow the emptying nut off  :shocked:
Offline GTi_James
Re: Oops!
« Reply #4 on: 12 December 2012, 12:12 »
well started it today and was a bit jerky, smoothed out after 2 miles though  :undecided: replacing with a new can now, would the drain plug cause lump idling?
