Author Topic: Water leak need help  (Read 1345 times)
Offline ian007miles
« on: 11 December 2012, 15:56 »
Hi every one. After having loads of rain the other day I notice that my driver side footwell is soaking wet. Has any one ever had this befor I've fone a search but can't find any thing so would much like the advice thanx Ian ps it's a 2 door Gti 18t no sunroof
« Last Edit: 11 December 2012, 17:09 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline Nino
Re: Water leak need help
« Reply #1 on: 11 December 2012, 17:02 »
I remember this happened to my focus and it turned out to be my suktle pannel, might be related?
Current - MK6 GTi Edition 35
Offline ian007miles
« Reply #2 on: 12 December 2012, 13:57 »
So I take it no ones had this problem then lol
Offline GTi_James
« Reply #3 on: 12 December 2012, 14:01 »
you got door nipples?
Offline ian007miles
« Reply #4 on: 12 December 2012, 16:11 »
No mate no sunroof
Offline GTi_James
« Reply #5 on: 12 December 2012, 16:43 »
check the rubber grommet that connects your interior to your exterior (ie brake and accelerator cables, bonnet cable) door seals? window seals?
Offline Ollie27
Offline ian007miles
« Reply #7 on: 14 December 2012, 14:18 »
Nice one mate ille have a go at that wen I get a chance
Offline 1 gti
« Reply #8 on: 14 December 2012, 19:50 »
Id put money on its the seal behind the door card. Take door card off and then you got a metal sheet which covers the regulator etc. the seal has gone on that most prob and coming over the sill. Just re-seal the metal sheet to the door and put door card back on
Offline ian007miles
« Reply #9 on: 15 December 2012, 16:34 »
Won't be that seal mate my doors are covered in dynamat sound proofing there's no gaps or wholes lol
