Golf mk3
hardmonkeys
Wet boot!
Topic: Wet boot! (Read 1590 times)
maxmc2
Wet boot!
11 December 2012, 15:14 »
Hi guys
Got a wet boot, been told to check the rubbers on the light fittings.
Are there any drain holes to look out for on the boot, if so whereabouts are they?
TIA
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Re: Wet boot!
11 December 2012, 15:35 »
The foam seals on the rear lights are probably past their best allowing water in.
maxmc2
Re: Wet boot!
11 December 2012, 15:59 »
Ok ill check that but ive just put a fresh set of lights on cant remember seeing any seals though.
Any drain holes anywhere worth checking whilst im at it.
thai-wronghorse
Re: Wet boot!
11 December 2012, 16:39 »
Thats probably the issue then, ive had aftermarket lights that haven't been supplied with them or the ones you get are poor fitting. Rob the ones off the old standard lights or buy new from VW.
tweed
Forum addict
Re: Wet boot!
11 December 2012, 20:20 »
That is his problem
The seal is stuck to your old lights no doubt.
Untitled
by
tweedub
, on Flickr
Wayne
Sir Postalot
Re: Wet boot!
11 December 2012, 22:02 »
Just buy a new pair of gaskets for the rear lights from VW they are not expensive and they go flat over time.
Len
10k hero
Re: Wet boot!
Reply #6 on:
13 December 2012, 13:24 »
Its a wonder your rear lights are working if that has let so much water in!
www.sas.org.uk
www.the-ace.org.uk
Golf mk3
hardmonkeys
Wet boot!
