Author Topic: help. uni work. stuck on easiest part of assignment  (Read 1760 times)
Offline mcgee9t2
« on: 09 December 2012, 16:39 »
got an assignment that has to be submitted by midnight tonight, have it all done, but one question, and i cant for the life of me do it. i must have spent around 4 hours today and 2 or 3 yesterday trying to do it.
basically its a simoultanious equation.
"given: Va=Ra Ia + K1 N and Te=T0 + K2 Ia
Estimate coefficients for Ra, K1, T0 and K2."
started with the first given equation, got:
@10%    25 = 1.8 Ra + 950 k1
@20%    25 = 3.2 Ra + 900 k1
now i know its a simoultanious equation, and i know that i have to do the same with the 2nd given equation to get T0 and K2. however i havent done a simoultanious equation for years.
so far this is what ive got.
Divide equation 2 by Ia at 20%
25 /3.2  =  Ra (900/3.2) k1
7.8125 = Ra + 281.25 K1
7.8125 - 281.25 K1 = Ra
and at that point i get stuck, anybody able to give me any pointers on were i go from here. had a look on google ect. but that just confused me more.
and before anyone says, we havent covered this is lectures, we have coverd the formulas but not simoultanious equations. we have no notes on this ect ect ect. my notes was the first thing i looked at, then i had a google, then asked my parents, then asked a few lads who i go to uni with and there all stuck on it too. this is litterally a last port of call. no im not wanting someone to work it out for me im happy with doing that, just pointers in the right direction cause at the moment ive done 6 hours of reading about them and scribbling things down but just cant get my head around it and seem to be going around in circles.
cheers
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: help. uni work. stuck on easiest part of assignment
« Reply #1 on: 09 December 2012, 18:54 »
Haven't done simul eqautions for years, and without digging out my old college stuff I won't be able to tell you!
Good luck my friend!  :lipsrsealed:
Offline Seanl
« Reply #2 on: 09 December 2012, 20:16 »
Not gone that far into it, but here are the types we've been doing for our engineering degree.
I will give you an example and talk through the process, then you can possibly adapt it for your equations to fit.
A simultaneous equations is basically just figuring out the two unknowns. Here the unknowns are x and y.
* Begin by rearranging your equations to follow the format ax + by = c
*Multiply the equation so the one of the unknowns has the same value in every equation.
*Add or subtract one equation from the otherto get rid of one unknown, and solve for the second.
*Substitute the answer into one of the original equations, and solve for the other unknown.
You can then check both answers.
First get your two equations one above the other, and number them.
(1) 4x - 3y = 11
(2) 3x + 5y = 30
Multiply 1 by 2, and 2 by 1,
(1) 4x - 3y = 11 (x3)
(2) 3x + 5y = 30 (x4)
(3) 12x - 9y = 33
(4) 12x + 20y = 120
Next step is to simplify. Both equations begin with 12x, so they equal the same, and cancel each other out.
Subtract equation 3 from equation 4
(5) 29y = 87
Then transpose out.
y = 87/29
y = 3
You then substitute the answer into the first equation, so;
4x - 3y = 11   becomes
4x - 3(3) = 11
4x - 9 =11
Then transpose again, so;
4x = 11 (+) 9
4x = 20
x = 20/4
x = 5
You can then make sure its right;
4x - 3y = 11
4(5) - 3(3) = 11
= 20 - 9 = 11!!!!!!!!!!
Hope this goes some way to explaining it for you mate, and hope you get it done! All the best!
Offline mcgee9t2
« Reply #3 on: 09 December 2012, 21:27 »
Spot on that sean. cheers mate. hopefully got it now.
VW BUSH
« Reply #4 on: 09 December 2012, 22:03 »
Well done Seanl, I could not work it out for the life of me :grin:
Offline tweed
« Reply #5 on: 09 December 2012, 22:11 »
=7?
Do I win?  :grin:
Offline bobotheclown
« Reply #6 on: 10 December 2012, 15:24 »
is this rocket science?  :shocked:
Offline scarr89
« Reply #7 on: 10 December 2012, 16:49 »
Brings back vivid memories Seanl  :wink:
That does make a lot of sense now remembered it!  :smiley:
Offline Seanl
« Reply #8 on: 10 December 2012, 18:15 »
Unfortunately for me, thats just the simple stuff! I've done a bit of maths now, (transposition/logs/quadratics/simultaneous/complex numbers/trianges/linear graphs/polynomial division etc.......... as well as the standard ratios/volumes yadda yadda yadda.
Got the difficult stuff in May when I get back on to it! Bit of a break after xmas until then, so hopefully some down time in the car club!  :cool:
VW BUSH
« Reply #9 on: 10 December 2012, 20:00 »
Good luck I'm 15 years out the back of my Exams, the only thing I still use is trig good job too cos the rest has been lost through various brain farts and meltdowns :grin:
