Author Topic: BREAKLIGHTS NOT WORKING??  (Read 2430 times)
Offline Foreveryoungaus16v
« on: 09 December 2012, 16:12 »
Hi, my breaklights are not working.  I have checked the bulbs and fuse and they are fine.  Any sugestions?
163 BHP (TSR POWER RUN)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: BREAKLIGHTS NOT WORKING??
« Reply #1 on: 09 December 2012, 16:20 »
Brake pedal switch?  Poor wiring connection at the rear clusters?
« Reply #2 on: 09 December 2012, 16:23 »
I took the break pedal switch off, is there meant to be a fuse to see if its blown??
Offline tweed
« Reply #3 on: 09 December 2012, 16:25 »
No. They just wear out.
« Reply #4 on: 09 December 2012, 16:30 »
The breaklights went when I was fiddling with the wires at bk of lights...could that blow the break pedal switch?
Offline tweed
« Reply #5 on: 09 December 2012, 16:37 »
 :grin: :grin: :grin:
No, clearly what ever you fiddled with is the problem.
This should have been in your first post
Offline wakeskater
  • H20 PHW MK3 16V DAILY ,,,MK1 16V PROJECT,,
« Reply #6 on: 09 December 2012, 16:50 »
Thinking my brake light swicth has gone to day can you do a test
« Reply #7 on: 09 December 2012, 17:32 »
how could i sove this?
Offline Len
« Reply #8 on: 10 December 2012, 12:38 »
Go fiddle with the rear clusters agin! You must have dislodged something. Also check the earth above the drivers side cluster.
www.sas.org.uk
www.the-ace.org.uk
« Reply #9 on: 10 December 2012, 17:15 »
Sorted!  Bloody fuse was not checked properly lol :grin:
