Golf mk5
p0011 fault
Topic: p0011 fault (Read 9057 times)
matping
Here all the time
MK1 20vT MK5 GTI T
p0011 fault
07 December 2012, 21:09 »
hi guys just done a scan on the ecu as the EML light is on and got this fault code p0011 can anyone shed any light on this ? is it time too panic as its to do with the timing apparentlly
i have a 2.0 TSFI DSG . and the last thing i need is the belt too go
topher
Administrator
Serious forum addict
fully functioning
Re: p0011 fault
08 December 2012, 10:07 »
http://wiki.ross-tech.com/wiki/index.php/16395/P0011/000017
I'd get your timing checked asap!
i also seem to recall blocked pickup pipe/oil pump problems bringing this fault code up, not enough pressure to pump up the hydraulic cam adjuster.
Last Edit: 08 December 2012, 10:58 by topher
matping
Here all the time
MK1 20vT MK5 GTI T
Re: p0011 fault
08 December 2012, 13:49 »
ive booked it in for a cambelt monday at my vw dealer , the EML light is also still on so they going too look at that aswell ! ill let you know the outcome as soon as its done !
matping
Here all the time
MK1 20vT MK5 GTI T
Re: p0011 fault
10 December 2012, 20:07 »
had the cambelt and tensioner done today the fault code apparentlly was low fuel related
i dont really believe that , it says on the invoice fault code erased and to be monitored by driver ! i think the fitter has just deleted it
Last Edit: 12 December 2012, 19:37 by matping
matping
Here all the time
MK1 20vT MK5 GTI T
Re: p0011 fault
11 December 2012, 09:26 »
And the light is now back on ! Not good
topher
Administrator
fully functioning
Re: p0011 fault
11 December 2012, 21:35 »
if they're saying the fault code was fuel related your P-code might be misleading. can you get the vag specific fault code from it now that the light is back on?
matping
Here all the time
MK1 20vT MK5 GTI T
Re: p0011 fault
Reply #6 on:
12 December 2012, 19:36 »
right here goes ive just re scanned it mate ,
00017 BANK 1 CAMSHAFT A (INTAKE) : RETARD SETPOINT NOT REACHED (OVER-ADVANCED) P0011 NO SIGNAL COMMUNICATION INTERMITTENT
thats what im getting all the time
matping
Here all the time
MK1 20vT MK5 GTI T
Re: p0011 fault
Reply #7 on:
30 December 2012, 16:59 »
any ideas anyone? ive just changed the camshaft adjustment valve incase it was that ! cleared the code and it came back on
only thing now is the fuel pumo relay but honestly cant see that
Jamie_r
Re: p0011 fault
Reply #8 on:
09 January 2013, 12:53 »
I've got the same code on mine coming up so any help would be great. I'm taking mine to garage to get checked so will let you know if I have any joy
I was think tho could it not just be a fact of replacing the sensor?
matping
Here all the time
MK1 20vT MK5 GTI T
Re: p0011 fault
Reply #9 on:
20 January 2013, 18:57 »
any luck bud ?
Golf mk5
p0011 fault
