Author Topic: NEEDED: original mk 1 golf clocks!!!  (Read 3267 times)
Offline chelseadagger
« on: 06 December 2012, 11:23 »
Im trying to purchase some original clocks for my mk 1 golf gti cabriolet as the ones in mine are not the originals and dont actually work correctly.
If any one has any or has any idea were i could get some originals from this would be a big help :D x
Offline chalky white
Re: NEEDED: original mk 1 golf clocks!!!
« Reply #1 on: 28 December 2012, 11:02 »
Hi,
what doesn't actually work as there are a few different cures for this issue?
For instance there is usually a brown/white wire that is connected to the rocker cover stud on the rear right corner, this in turn has an earth braid that goes to the coil mounting bracket bolt. This earths the clocks and keeps the thing from going haywire.
Another common problem for totally dead clocks is the voltage regulator on the rear of the clocks. Plus check for signs of damage to the Blue plastic foil circuit board.
Usual suspect though is a poor connection on the actual plug to the clock unit. So take the whole assembly out out unplug the connector, clean the contacts on the foil and then, slide the ribbon off the plastic tab. Wrap a couple of turns of insulating tape around the tab to make it thicker, then replace the foil back over the tab and reconnect this should allow for better contact between the foil contacts and the connector it's self.
« Reply #2 on: 28 December 2012, 16:43 »
There are also 2 manufacturers Motometer and VDO.
If yours is the GTI it should have the MFA display also.
Pics of what you have in yours at the moment will assist also.
I would try E Bay.
cheers
Chalky
