Author Topic: Power steering issue  (Read 1284 times)
Offline maxmc2
« on: 05 December 2012, 21:10 »
Evening guys
Power steering issue, when I steer to the left the steering is light and when I steer to the right it's noticable heavier.
I've checked the fluid and all is fine there.
When I got the vehicle the guy had removed the air con unit as this had siezed up.
Good that be related to my steering issue?
TIA
Offline Len
Re: Power steering issue
« Reply #1 on: 06 December 2012, 12:42 »
Well one would have to assume he fitted a new belt as by removing the aircon compressor you have to fit a shorter belt.
So cant be that!
Might be top mounts or any of the steering components.
Is the car lowered?
Have you had tracking/alignment checked?
www.sas.org.uk
www.the-ace.org.uk
Offline maxmc2
« Reply #2 on: 06 December 2012, 17:04 »
So cant be that!
Is the car lowered?
Well thats what i thought re: the belt ill have to check that, i know the difference in belt size is 70mm.
Top mounts as in suspension??
Yes car is lowered and no haven't had the tracking or alignment checked yet.
Offline maxmc2
« Reply #3 on: 07 December 2012, 16:14 »
OK had the tracking and alignment done and checked the belt tension.
Next port of call?
