Author Topic: Pressure low fault! Check D.V  (Read 1512 times)
Offline Tezmax
« on: 04 December 2012, 16:06 »
Hi Guys,
Got a EMS light up again...dont take long does it :sad:
Pressure low between throttle and turbo check D.V!!
Its amazing how those jubilee clips can move into a position where they groove holes
in every rubber pipe under your bonnet :laugh:
Anyway couldn't find any visible holes but found the two union connectors fitted to my
catch can were lose.
Would this cause the low pressure fault or do i need to check abit more indepth.
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Delta-Force
Re: Pressure low fault! Check D.V
« Reply #1 on: 07 December 2012, 11:07 »
fault 17705 ?
its usually caused because the bottom turbo to charge pipe wears it has a clip that holds it in place that wears into the alloy joint the pipe looks like this
this is what happens under load it comes apart
you can eather replace the pipe was about £52 last time i bought one or replace the charge pipe from one off and agu engine code as they use jubalee clips and are much better than the later clip type
Delta-Force
« Reply #2 on: 07 December 2012, 11:11 »
this is an agu charge pipe its the bottom pipe the later aum / auq engines have the alloy clip shown above but the agu has jubalee clips , best getting it in axel stands and its at the back of the engine ive fixed this fault a few times now
« Last Edit: 07 December 2012, 12:40 by Delta-Force »
Offline Nino
« Reply #3 on: 07 December 2012, 11:37 »
Sorry to jump in here but I keep getting this myself from time to time. I will check that pipe when i can.
If i was to change the pipes/clips can i ask is it an easy job and how isit done?
Current - MK6 GTi Edition 35
Delta-Force
« Reply #4 on: 07 December 2012, 12:24 »
It's pritty easy tbh mate if you replace the pipe with a new part you just remove one an fit the other straight forward really the hardest part is going from under the car as its at the rear of the engine and your working lay on your back lol
Offline Nino
« Reply #5 on: 07 December 2012, 15:54 »
I see, seems simple enough, and if i wasnt to go to VW and buy a new one could i source a 2nd hand one from somwhere other than a scrap yard?
Offline Tezmax
« Reply #6 on: 07 December 2012, 19:20 »
ahh, yes had this pipe connection pop out before when i changed my bosch Maf and caused fault
issues.
Will pop it back in when it stops raining and see after fault delete:smiley:
Thanks for the info and pics.
ta.
Offline rio_gti
« Reply #7 on: 07 December 2012, 22:46 »
10mm ring/ratchet spanner to get to the brackets that hold it on is the only fiddily bit  :wink:
Made a massive difference when I replaced mine with it  :smiley:
Delta-Force
« Reply #8 on: 07 December 2012, 23:53 »
No probs dude I had nightmares with that fault for quite some time on a cupra I had fixed a couple of golfs with it too now hope you get it sorted mate :)
Offline rfn_hodgson
« Reply #9 on: 09 December 2012, 11:42 »
i did this only last month i think only took me a little while :) easy
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
