Author Topic: kock & scraping sound when turning at low speed  (Read 1372 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« on: 04 December 2012, 15:02 »
Hi all,
I get the sound when going at low speed so mainly when pulling out of a parking spot or maneuvering the car on the street, the scraping sound kinda sounds like when you catch the front splitter on a curb, the knocking may just be my arb bushers.
Any idea what to look at?
Thanks
Mike
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline wotavudunn
Re: kock & scraping sound when turning at low speed
« Reply #1 on: 04 December 2012, 15:14 »
could be wheel hitting the coilover when on lock(presuming you have coilovers fitted) if not then arb on driveshaft
Offline dom
  • Back in a Mk4
« Reply #2 on: 04 December 2012, 19:55 »
My guess is also arb on driveshaft, mine is doing the same due to work arb bushes.
I'm running it low enough to just miss the driveshaft normally, but now the bushes are worn it comes into contact when on full lock.
Offline godsANGER
« Reply #3 on: 04 December 2012, 21:34 »
yer on coilovers had the same coilovers and wheels for 3 years, its only recently started
Offline godsANGER
« Reply #4 on: 04 December 2012, 21:39 »
well i have newish Poly bushers but.... i think i put a to long bolt on the clamps but about 5mm but on the other hand the clamps were tigth up, but could this be going enough play to hit the drive shaft?
not gone any lower on the front ether  :undecided:
Offline godsANGER
« Reply #5 on: 05 December 2012, 14:20 »
little  bump
Delta-Force
« Reply #6 on: 07 December 2012, 11:14 »
just jack the drivers side up mate you will see rub marks on the arb if its hitting if your useing standard arb and drop links its 90% its that rubbing i bought some ajustable droplinks and cut 2cm off the bottom longer part and 1" off the thread to make them shorter stopped it completly for me  :cool:
Offline asboGTI
« Reply #7 on: 07 December 2012, 13:40 »
Or buy a mk1 TT anti roll bar or anyone that goes under the drive shaft
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
