Yeah bought three washers and used some old bolts and screws then cleaned GPU CPU stuck some artic silver. Had to drill 7mm holes to make room for the bolt heads otherwise the PCB would not sit flush.
So far tried pulling fan out to overheat it to reflow 20mins
Tried hair drier 5mins
Tried sticking a low flame over the heat sink to reflow 1min
Still got three lights!
TBF need one of those heat plates and heat lights apprently need it about 440F odd to reflow?
Gave it my best shot but its over 7 years old and first time its failed.
On another note Alex the boiler PCB gave me sh!t as you know, and it wasn't the pump, as it locks out when its off and the water pump still runs on. I took the PCB off and cleaned it with alcohol wipes and dust spray.
Works fine now its only locked out once since rebuild, but fear its the same thing bad soldiering joints and overheating.
The new PCB requires new loom and fan which I couldn't be arsed
