Author Topic: front bearings?  (Read 1421 times)
Offline javalin
front bearings?
« on: 03 December 2012, 11:40 »
Morning all,
If front wheel rocks when pulled top-bottom, that’s bearing’s isn’t it?  Only does it when wheel is in a certain position, i.e. have to rotate it to find the spot.  Symptoms – vibration and play (bus) like steering when cornering, bumpy roads etc.
I don't think the front wheels are ajustable bearings are they?
ta,
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Len
Re: front bearings?
« Reply #1 on: 03 December 2012, 12:21 »
Have you checked the wheel bolts/nuts?
I only ask because if it is a wheel bearing it would rock top to bottom at every position of the wheel.
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
Re: front bearings?
« Reply #2 on: 03 December 2012, 14:03 »
yeah, bolts nice and tight.  oh and new bushes, top mounts and shocks in the last two years too.
Offline JamesS
Re: front bearings?
« Reply #3 on: 05 December 2012, 13:37 »
Does sound like a wheel bearing. If you let a wheel bearing get really bad it can cause vague steering/tramlining but by this stage there would be a mega loud noise & vibration. Try and nip it up, they shouldn't need to be nipped up but it is a temporary solution to prevent movement before you change the wheel bearing.
If you have checked all the bolts are FT (f***ing tight) then also check the lower ball joint for play. The easiest way to check for play in the suspension area is to get the car on a ramp/axle stands and use a huge screwdriver/crowbar to prize the joints and bushes apart to see if there is movement.
If you can hear knocking when coasting, lightly accelerating or lightly braking then this indicates worn ball joints or bushes. Try these things on a bumpy road.
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline javalin
Re: front bearings?
« Reply #4 on: 05 December 2012, 14:12 »
Hiya JamesS,
Thanks for that reply - most helpful.  Hadn't really thought of lower ball joint, probably as these are new (ish) too!  Will check it out.
I can sometimes convince myself that there is a wining from the o/s/f but not 100%
Cheers,
James
Offline tweed
Re: front bearings?
« Reply #5 on: 05 December 2012, 18:34 »
Sounds like bearing to me
Offline AudiA8Quattro
Re: front bearings?
« Reply #6 on: 05 December 2012, 22:49 »
Does the play go if you apply the brake pedal?
Don't try and nip the hub bolt up, there is no adjustment there...
Offline javalin
Re: front bearings?
« Reply #7 on: 06 December 2012, 09:14 »
didn't think the fronts were adjustable.....  Will have to check at the weekend re the play.  Brrr (-4c here today).
Offline tweed
Re: front bearings?
« Reply #8 on: 06 December 2012, 11:25 »
Wear gloves  :huh:
Offline Len
Re: front bearings?
« Reply #9 on: 06 December 2012, 12:34 »
Get a heated garage! :whistle:
www.sas.org.uk
www.the-ace.org.uk
