Author Topic: VR6 and switched live  (Read 1339 times)
Offline maxmc2
« on: 03 December 2012, 10:45 »
Hi all
Picked up a VR6 yesterday as a project and am scratching my head at the following.
Ive installed a radio only to find that both the perm and switched live of the radio loom on the vehicle are constantly live even when i remove the key.
Consequently im getting 130mA or thereabouts of drain on the battery so this will die over time.
Any reason why the switch live is always live??
When i remove the key from the barrel should it not pop out hence cutting the switched live?
Any help appreciated.
Offline sharki786
  • GOT BOOST??
Re: VR6 and switched live
« Reply #1 on: 03 December 2012, 18:12 »
i have the same problem, but my alpine turns off when i remove the face & also turns the amp off via the remote wire from the cd player to the amp.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tweed
« Reply #2 on: 03 December 2012, 18:54 »
I know you have to swap the power cables round
Offline MereKat
« Reply #3 on: 03 December 2012, 19:39 »
I had to swap them round on mine, but i have a faulty ignition switch anyway so switched live is always dead...could be that and previous owner has split the permanent live? (My pioneer needs both permanent and switched to have feeds to work, but the permanent can bridge to the switched on the iso connection)
Offline maxmc2
« Reply #4 on: 03 December 2012, 20:10 »
I'm figuring a faulty ignition switch as both switched and perm live on the cars radio loom are constantly love.
I seem to remember on my gti that when I removed the key the barrel ejected itself slightly but doesn't on my vr6
Offline CJA321
« Reply #5 on: 03 December 2012, 22:56 »
Yeah id defo go an ignition switch
