Author Topic: starting and high tick over  (Read 1873 times)
Offline dannyxr2i
« on: 02 December 2012, 21:02 »
hi all,
got issues with my 90's valver, when cold and start it up, takes a few turns to get it going and few presses on the accerlater, then when fires up ticks over at 3k till warmed up,
any ideas?
Offline Diamond Hell
  • Opinions я Us
Re: starting and high tick over
« Reply #1 on: 02 December 2012, 23:21 »
Run some injector cleaner through it to start.
Make sure the wires connecting the cold-start injector are in good condition and getting 12V.
Is the battery in good fettle?  Connections all clean around the starter?
Offline dannyxr2i
« Reply #2 on: 03 December 2012, 21:59 »
injector cleaner been ran through,and battery had charge up, did it again this morning, but left it standing at work for 12 hours and started up bang on, so see how goes 2moro am. cold start will look over it wednesday
Offline rich1977
« Reply #3 on: 04 December 2012, 21:00 »
It's used to do that to me in winter and it was the little micro switch on the TB no be operated due to TB not closing fully.
Www.Internet-ink.co.uk voucher code RL15 for 15% off all pens,toners and ink cartridges including cannon Epsom dell and hp.
Offline dannyxr2i
« Reply #4 on: 04 December 2012, 21:39 »
r right, how did you stop this? 1st time used it in cold (winter) as was garaged last year,
Offline rich1977
« Reply #5 on: 05 December 2012, 17:29 »
cleaned the tb body and adjusted the cable to ensure it closed fully, it might not be that but sounds like it.
when started with engine open grab the TB linkage and pull it shut to ensure the arm contacts the switch and see if revs drop.
hope this helps.
Offline Gambit
« Reply #6 on: 06 December 2012, 11:07 »
and you can also test the throttle body switch simply by holding the throttle open by hand above 2.5k rpm then pressing and holding the microswitch with your finger. the rev's should then plummet and then lift back up again, and continue to do so until you release the switch
Offline dannyxr2i
« Reply #7 on: 06 December 2012, 21:18 »
brill will try this saturday morning,
Offline dannyxr2i
« Reply #8 on: 09 December 2012, 23:43 »
hi, had look over the car 2day, and seems when cold the throttle bar donest touch the mircoswitch, few mm gap, so should i clean this out and go from their? but looking at geting another 1 to see as my throttle cable adjustment screw has snaped now.
