Author Topic: If these fit an A3...........  (Read 1410 times)
Offline p3asa
Offline wigit
Re: If these fit an A3...........
« Reply #2 on: 01 December 2012, 21:51 »
If you use an online offset calculator they will give you an idea how they sit compared to stock, which from memory ar 7.5j and 51 offset
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 01 December 2012, 22:10 »
9J with a 52 offset youl be luckie I expect inner arch mounting screw scrape if not more. 8.5 is about max.
215 will look very stretched, very scene but  :lipsrsealed:
« Last Edit: 02 December 2012, 09:36 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Ess_Three
« Reply #4 on: 02 December 2012, 05:43 »
It will be VERY tight...I run 8.5" x 19 ET52 and it's close on both the outside and inside of the front with a 225 tyre.
With a 235 wide tyre, they have been known to rub the arch liner on the inside...so a 12mm wider wheel is likely to have the same effect.
Consider whether there are insurance implications to fitting narrower tyres than OEM.
Also, the rim protector is of no practical use on a 225 tyre, on a 8.5" wheel...the same tyre on a 9" wide wheel would look too stretched in my view, too scene, and utterly shyte.  :whistle:
..but gaining motorcycles.
Offline The Doc
  • E63s Estate - Vito Sport
