Author Topic: Cold Starts  (Read 3521 times)
Offline drc12369
Cold Starts
« on: 30 November 2012, 22:16 »
So its that time of year again and after leaving the car alone for 5 days  or so when i come to start it, it takes a few attempts and upto a minute or two to fire up. So what can i do to improve this? Im fitting new spark plugs Sunday (NGK BUR6ET) so what else can i do to help thats cheap and easy?
Offline sharki786
  • GOT BOOST??
Re: Cold Starts
« Reply #1 on: 30 November 2012, 22:27 »
stick a duvet cover on the engine (make sure you remove it when you start the car
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline drc12369
Re: Cold Starts
« Reply #2 on: 01 December 2012, 09:37 »
Anybody with anything helpful to say?
Offline itavaltalainen
Re: Cold Starts
« Reply #3 on: 01 December 2012, 10:24 »
check dizzy cap if moisture is in there, same for cables
check engine temp sensor using an ohm meter (multimeter - 10£ one from b&q/homebase/halfords will do):
it's a dual sender, one goes to your instruments the other to ECU... if it's broken the engine would use a standard value, in cold weather that could cause too little petrol being injected...
if you got a diode test lamp or an oscilloscope (or a cheapish ebay DSO) check if the crank sensor is working when you crank the engine, although this would normally also give you trouble when it's warm.
Offline sharki786
  • GOT BOOST??
Re: Cold Starts
« Reply #4 on: 01 December 2012, 22:10 »
you think im having a laugh?
people do that.
its mainly because its nearl enough 0 degs in some areas. :whistle:
« Last Edit: 01 December 2012, 22:16 by sharki786 »
*****MK4 GTI T*****
Offline drc12369
Re: Cold Starts
« Reply #5 on: 01 December 2012, 22:41 »
Im doing the plugs tomorrow, if that doesnt help i might just do the ht leads and dissy cap. Does anybody know the vag part no for a 97 2.0 8v 1H AGG gti dissy cap?
Christo77
Re: Cold Starts
« Reply #6 on: 02 December 2012, 12:02 »
May not be much help exactly but i've noticed with mine it won't start unless there's sufficient cranking speed, anything below par and it'll spin away no go.. suggest's battery has to be in top order/correct rating as a first port of call (my case) although other usual suspect areas all have a say in the matter probably.
Christo
Offline drc12369
Re: Cold Starts
« Reply #7 on: 02 December 2012, 14:34 »
It just doesnt seem to like being left for a week and starting in a frost. Id used the car yestetday but it started first time this morning at 9am with a nice thick layer of frost all around.
Offline Foreveryoungaus16v
Re: Cold Starts
« Reply #8 on: 03 December 2012, 11:47 »
U can get all the parts like dizzy cap etc from GSF
163 BHP (TSR POWER RUN)
Offline Len
Re: Cold Starts
« Reply #9 on: 03 December 2012, 12:19 »
or ECP with forum discount! :whistle:
No car likes standing for long periods as alarm/immobiliser will drain the battery.
If you know you are not going to use the car then disconnect the battery, its very quick and simple to connect up again.
And yes the battery should be in top condition for cold starts.
www.sas.org.uk
www.the-ace.org.uk
