Author Topic: Excel Help  (Read 1214 times)
Offline R32UK
Excel Help
« on: 30 November 2012, 12:50 »
Been a while since I used excel and need some help from an excel wiz if possible.
e.g. I have a list of random names in a list some of them repeated numerous times.
mat
mat
mat
john
alan
alan
I would like to turn this into a list of names without duplicates and the frequency each name appeared. So the list above would end up like
mat 3
john 1
alan 2
Many thanks!
Offline logeyboy
Re: Excel Help
« Reply #1 on: 30 November 2012, 13:48 »
I have a blank spreadsheet with Macros embedded to do this, unfortunately I don't know how to view the macros, but I could e-mail you the sheet?
Offline logeyboy
Re: Excel Help
« Reply #2 on: 30 November 2012, 13:50 »
Try this...
Sub RemoveDuplicates()
    ' Sort by column 1...
    Cells.Sort Key1:=Range("A1")
    ' Determine number of rows used in worksheet...
    totalrows = ActiveSheet.UsedRange.Rows.Count
    ' Initialize counter...
    Count = 1
    ' Step through the rows in reverse order with "Step -1".
    For Row = totalrows To 2 Step -1
        ' Check value in column 1 to see if it is the same
        ' as the previous row...
        If Cells(Row, 1).Value = Cells(Row - 1, 1).Value Then
            ' Found a dupe. Delete it and increment counter
            Rows(Row).Delete
            Count = Count + 1
        Else ' Not a duplicate. This is a new record, so...
            ' put the counter value in the spreadsheet for
            ' the previous record:
            Cells(Row, 3).Value = Count
            Count = 1 ' reset counter for new record
        End If
    Next Row
    ' Don't forget last record (which is actually first)...
    Cells(1, 3).Value = Count
End Sub
Offline Ridg
  • TDI - Soot Happens!
Re: Excel Help
« Reply #3 on: 30 November 2012, 15:05 »
alternatively select data from the ribbon, select the cells, click group and then click subtotal which gives you a drill down for each item.
You might want to consider using access and not excel for this.
Offline R32UK
Re: Excel Help
« Reply #4 on: 30 November 2012, 15:07 »
Thanks guys. Help very much appreciated!
You would think its much easier than this... and it is. Only I was wasnt using a full version of excel. With a full version downloaded I was able to do this very simply using a pivot table.
All sorted now  :smiley:
Thanks again  :cool:
Offline Egbutt Wash
Re: Excel Help
« Reply #5 on: 30 November 2012, 18:31 »
Wack it each time with summat like this
Sub Auto_Open()
Application.OnSheetActivate = "Numpty"
End Sub
Sub Numpty()
Dim iP As Integer
Application.DisplayAlerts = False
For iP = 1 To ActiveSheet.PivotTables.Count
   ActiveSheet.PivotTables(iP).RefreshTable
Next
Application.DisplayAlerts = True
End Sub
Currently digging a bunker.
