Author Topic: Gearbox info required please :)  (Read 1099 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 28 November 2012, 21:41 »
Evening chaps on mk3 golfs is it only the 16v abf boxes that run a cable change as the 8v ones run a rod change is that true on all the 8v models ? Thanks :)
VW BUSH
Re: Gearbox info required please :)
« Reply #1 on: 28 November 2012, 22:53 »
Yep, all 8v Mk3's and all Mk2's run rod change boxes.
Mk3 16v and VR6 run cable change with hydro :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 28 November 2012, 23:54 »
Seat Ibiza 16v's have a hybrid version of both types of clutch though. Some people use the pedal boxes out of these to get around the cable to hydro issue.
Offline Jimmyrallye
  • 20vt goodness
« Reply #3 on: 29 November 2012, 12:23 »
Cool thanks guys it just ive fitted a abf gearbox with cables on my mk2 20vt and have noticed the gear ratios are very long!! It wos so much faster when i had the old 8v box with the rods ect just wondered if i could bolt a 8v back on and keep cables but you cant .... Thanks :)
Offline spikenipple
« Reply #4 on: 29 November 2012, 17:30 »
You could fit a different final drive to perk it up a bit.
