Author Topic: diagnostic question on fuel pump ?  (Read 1308 times)
Offline sparkplug
« on: 28 November 2012, 20:54 »
my son has just got a Mk3 1.4 (yeh 1.4...i know but he needs cheap insurance)
the fuel pump is playing up & blowing the 20A fuse ,no short circuits to earth
 seems its drawing too much current, but can't decide if the pump is going home
... or maybe the fuel filter is blocked causing the excessive loading of the pump
anyone had similar symptoms ?
1986 GTI atlas grey
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
Re: diagnostic question on fuel pump ?
« Reply #1 on: 28 November 2012, 20:58 »
replace pump its clearly had it... blocked filter would cause this...
...Burn Rubber...Not Your Clutch...
Offline tweed
« Reply #2 on: 28 November 2012, 21:38 »
What about the relay?
Offline sparkplug
« Reply #3 on: 29 November 2012, 20:37 »
cheers for the reply  :smiley:
tweed... tried the relay , but problem is still the same
 hainesz...got the old pump out ,seems to be a pattern one as has no VW part number on it
 going to replace the pump , ordered one today , fingers crossed
« Last Edit: 29 November 2012, 20:39 by totalnuttah »
1986 GTI atlas grey
Offline sparkplug
« Reply #4 on: 01 December 2012, 21:08 »
the previous owner had a ,new cat. converter & lambda sensor fitted last week....
seems they(garage) broke the heat feed cable on the lambda sensor, this flapping about is what was blowing the fuel pump fuse,as they share the same fuse
took me a while to sus it out
so the lesson is just because its a new part ,don't mean it aint broke  :rolleyes:
« Last Edit: 02 December 2012, 16:07 by totalnuttah »
1986 GTI atlas grey
Offline Stewy12
« Reply #5 on: 02 December 2012, 09:42 »
seems they(garage) broke the heat feed cable on the lambda sensor, this is what was blowing the fuel pump fuse,as they share the same fuse
+1 that will be them problem i had the same problem replaced fuel pump relay fuses and still kept blowing... unplug sensor from under bonnet replace fuse and see if it stops blowing if so replace sensor again...
