Author Topic: boost gauge  (Read 6720 times)
Offline NERF 69
Re: boost gauge
« Reply #10 on: 28 November 2012, 21:42 »
Ah good man glad i asked now. Where is the pipe you plumber yours into? I've had a quick look before for the intercooler but couldn't find it. What engine have you got? Mines the 110 pre pd will it be in the same place?
Sell my Vw??? I'd rather stick wasps up my arse
Offline Rhyso
Re: boost gauge
« Reply #11 on: 29 November 2012, 01:48 »
Intercooler is under the drivers side headlamp
Find the big black pipe on the side of the engine. It starts at the back and works its way towards you. Look at my project thread and see where I replaced it for a blue item  :smiley:
Mine was the 130PD but the pipework layout is broadly the same  :smiley:
« Last Edit: 29 November 2012, 02:08 by Rhyso »
Offline NERF 69
Re: boost gauge
« Reply #12 on: 29 November 2012, 09:55 »
Right. Assuming the big black pipe im looking at is the right one (comes over the top of the engine to the top of the intercooler) i still cant find the pipe to plumb into. I cant find anything that resembles your picture. Probably me looking with my eyes shut lol. Could you go into abit more detail if possible. Thank you
Offline Rhyso
Re: boost gauge
« Reply #13 on: 29 November 2012, 11:03 »
That is the pipe you plumb into  :smiley:
I had an EGR delete pipe with the takeoff built in.  You will have to drill and plumb into that big black pipe yourself  :smiley:
That help??
Offline NERF 69
Re: boost gauge
« Reply #14 on: 29 November 2012, 11:29 »
How did you keep it air tight?
Offline Rhyso
Re: boost gauge
« Reply #15 on: 29 November 2012, 11:54 »
Thats the challenge  :grin:
You buy dedicated take offs which you insert into the pipe. They should come with a sealing ring  :undecided:  equally do not make the hole too big; you should have to force the take off in so as to keep it as air tight as possible  :smiley:
Other option is to do what I did and buy an EGR delete pipe which comes with the take off plumbed in  :smiley:
Offline NERF 69
Re: boost gauge
« Reply #16 on: 29 November 2012, 14:35 »
ThanKs for all the advice its been a big help. Ive ran the vacuum hose through the bulk head and wired it into the head light switch im just waiting on abit of info on plumbing it into the pipework. I rang the old man up who deals in hydraulics and hes gonna see what i can do to keep it air tight. One more question just to make sure im on the same wave length as you if i put the vacuum hose into the elbow piece before the egr that would work is that right?
Offline Rhyso
Re: boost gauge
« Reply #17 on: 29 November 2012, 19:36 »
Yep thats all the same pipe  :smiley:
