Author Topic: Fitting a different steering wheel with no air bag  (Read 1297 times)
Offline Mk2_tel
« on: 28 November 2012, 13:08 »
I have the Bose..... Is there a resister I can buy to turn off
Airbag light or do u have to deal with it on?
Offline SI74
Re: Fitting a different steering wheel with no air bag
« Reply #1 on: 28 November 2012, 13:36 »
Car won't pass MOT with it on. I think you can blank them and make the car think its still there.
Offline wotavudunn
« Reply #2 on: 28 November 2012, 16:18 »
it will pass the MOT. i have a aftermarket steering wheel and the airbag light was an advisory. but you can switch it off with vagcom.
Offline houston
« Reply #3 on: 28 November 2012, 17:06 »
if the airbag light is on and the airbag is still there then its an mot failure, you were luckt to get a tester who passed it.
dont just remove the bulb or bodge it with a resistor, go on vagcom and disable it, cos dont forget the passenger bag
Offline xxChrisxx
« Reply #4 on: 28 November 2012, 17:18 »
You had your MOT before April then.
Airbag or indeed any warning relating to safety = fail.
Offline rockmonkey69
« Reply #5 on: 28 November 2012, 17:21 »
As Houston suggested, you can disable specific air bag units via vag-com/vcds. I don't think you need a resistor if you have disabled it via vag-com/vcds because I remember fitting aftermarket seats which did not have airbags fitted and I simply disabled it via VCDS with no airbag light.
You do however get a message on the display when you first turn the key to warn you that the said airbag has been disabled.
Offline wotavudunn
« Reply #6 on: 28 November 2012, 18:37 »
no, last week it was an advisory.
Offline wotavudunn
Offline Ant1981
  • Feed me, prod me
« Reply #8 on: 28 November 2012, 18:53 »
Dodgy MOT tester.
He should have looked to see the car had been tampered with and left in an unroadworthy condition with no airbag.
'09 Kawasaki Ninja ZX-6R
