Author Topic: my immobiliser light has come on and i cant start my car help  (Read 6262 times)
Offline djmagpie
my immobiliser light has come on and i cant start my car it starts 4 2 sec then cuts out  pluged in my fault  put my finder on the car and has come up code 17978 how can i get thois fixed asap
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
Re: my immobiliser light has come on and i cant start my car help
« Reply #1 on: 27 November 2012, 18:44 »
Have you done a google search for code 17978,there's quite a few threads mate.
Offline opel
« Reply #2 on: 27 November 2012, 18:55 »
17978/P1570/005488 - Engine Start Blocked by Immobilizer
Possible Symptoms
Engine starting but stalling immediately
Possible Causes
Key(s) not matched
Instrument Cluster not matched
Engine Control Unit (ECU) not matched
Engine Control Unit (ECU) Power Supply faulty
Possible Solutions
Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some)
Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module)
Match Key(s)/Instrument Cluster/Engine Control Unit (ECU)
Check Engine Control Unit (ECU) Power Supply (Relay)
Special Notes
In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related.
May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module.
If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, in rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example)
Low battery voltage (including a faulty battery) may cause Immobilizer system malfunctions and testing should be done only with a known good battery installed.
Offline djmagpie
« Reply #3 on: 27 November 2012, 18:56 »
yeah just cant see .. how to get the problem  fixed m8
Offline djmagpie
« Reply #4 on: 27 November 2012, 18:59 »
ive drove the car fine earlier so a bit confuzed do i need to get the chip in the key redone ?? if sso were do i go 4 that?? cheers
Offline opel
« Reply #5 on: 27 November 2012, 19:04 »
have u tired disconnect your battery for a while then connecting it up again
Offline djmagpie
« Reply #6 on: 27 November 2012, 19:06 »
yeah tryed that m8 still with no joy  :sad:
Offline Rhyso
« Reply #7 on: 27 November 2012, 19:07 »
Replaced the battery in the keyfob?
Offline djmagpie
« Reply #8 on: 27 November 2012, 19:16 »
got the car started now by removeing the battery leads and putting them 2gether again and cars sorted  :smiley: thanks 4 all ur posts anyone no wat maybe causeing this and how to fix so dosent do it again cheerd
Offline dixie180
« Reply #9 on: 27 November 2012, 20:06 »
Battery voltage,ie faulty battery.??
Rob
