Author Topic: MK1, not quick start in the morning :-(  (Read 1600 times)
Offline kidhannn
« on: 18 July 2005, 15:55 »
Hi All,
I recently bought a MK1 1.8 GTI Cab.
Car runs fine but being a GTi (injection), I thought it should start fairly quick at any time.
Car seems to take time to start early morning. Also if car hasnt been driven for several hours..... Have to get the starter turned for several seconds before the car starts......
Any ideas why is this the case?
Randeep
Offline hc-animal
Re: MK1, not quick start in the morning :-(
« Reply #1 on: 18 July 2005, 17:38 »
could be the injectors leaking and fouling up the plugs?
Offline bens_Cab
« Reply #2 on: 19 July 2005, 14:39 »
check you have fuel pump noise on ignition if not change the fuel pump relay number 62 with brown bottom if you have a 62 with a white bottom its from a mk2
Ben
