Author Topic: Which one of these ...  (Read 1578 times)
Offline Mark b
« on: 27 November 2012, 14:00 »
Will I need to check for my rear wiper was going to check to rule it out
Standard gti 2.0 115bhp 2000 w reg
Offline mcgee9t2
Re: Which one of these ...
« Reply #1 on: 27 November 2012, 15:17 »
i belive the black one with 409 on it is for the fueling iirc so can rule that one out.
all the relays should have a part number on it which you can check to see what its the relay for.
EDIT: just noticed the part number is veiwable and went on google and searched it and it came up with fuel pump relay
Offline Mark b
« Reply #2 on: 27 November 2012, 15:31 »
Cheers for the reply I did a quick search and think its the big brown. The prob may not be the relay but just wanna rule it out is there a way of testing it to see if it has power ? Also does the relay operate the front and back or just the back as the front wipers are fine
Offline mcgee9t2
« Reply #3 on: 27 November 2012, 15:36 »
not sure weather its one relay for back and one for front, would imagine it is though,
find out the output terminals and put a probe on it to see if your getting an output when the wipers are turned on, if not then theres either a fault with the relay or something before the relay.
Offline Mark b
« Reply #4 on: 27 November 2012, 15:55 »
I'm hoping its either the relay or a broken wire does the relay just pull out ? Sorry if these are stupid questions but I've 0% knowledge about cars
Offline Tezmax
« Reply #5 on: 27 November 2012, 17:02 »
Change Relay 100
My Wipers, indicators and heater fan all stopped working and after several searches and
assistance on here i just changed the lot.
When i got to No.100 everything started working fine :wink:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline Mark b
« Reply #6 on: 27 November 2012, 17:12 »
I'm hoping its a reley as couldn't find a broken wire
Offline Mark b
« Reply #7 on: 28 November 2012, 13:31 »
Got down under to to relays and there is clicking from the front wiper but when I did the back wiper there was no noise no clicking should I put it down to a relay fault then ?
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #8 on: 28 November 2012, 17:52 »
Pic of wiper relay, I've also read there isn't a relay for rear wiper but this is the relay for windscreen wipers so why wouldn't it operate the rear one too?...
Offline Mark b
« Reply #9 on: 28 November 2012, 17:57 »
Thanks for that I've read somewhere there isn't one for the rear but been told there is quite confusing I don't have the 377 black one on my relay board the one I have is a brown 603 but when I operate the rear wiper stalk I can't hear no clicking ?
