Author Topic: ross-tech.com/wiki fault codes?  (Read 3912 times)
Offline Keithuk
« on: 27 November 2012, 13:02 »
Hi guys.
As you know I've made EOBD II Fault Codes Software.  But if you check codes on http://wiki.ross-tech.com/wiki/index.php/16484/P0100/000256 it shows 3 numbers. In this example 16484/P0100/000256 I know P0100 is EOBD II code and I assume 16484 is the VAG code.
Does anyone know what 000256 stands for and is 16484 a VAG code as wiki doesn't explain?
I've downloaded other codes and for the same number that shows:
P010000 dtc_vag 4064 dtc_sae 00065536 pcode P0100 Mass or Volume Air Flow Circuit
I've asked the same question in other forums but no one has replied.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
