Author Topic: Intermitent slipping clutch???  (Read 1693 times)
Offline sharmalini
« on: 27 November 2012, 09:46 »
I have a Golf gt tdi pd130 with a jabbersport remap. I think my clutch is slipping but it doesnt do it all the time? Is this possible? i assumed that once it starts slipping then it would slip all the time? I know its stupidly expensive to replace one of these from the quotes ive had.
Offline shaft69
Re: Intermitent slipping clutch???
« Reply #1 on: 27 November 2012, 11:04 »
Get sachs vr6 clutch and g60 flywheel of ebay £170, be about 150 fitting get 3hr to fit clutch and flywheel. mine getting done next Thursday.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline sharmalini
« Reply #2 on: 27 November 2012, 11:46 »
Yeh i contimplated that but my mechanic mate says that they struggle to handle the torque?
Offline JimBR
« Reply #3 on: 27 November 2012, 12:53 »
Id be careful putting a VR6/G60 combo in a tdi, it will probably rattle like hell.
http://www.youtube.com/watch?v=Vb9Z6O_Czow
Id stick with an OEM dual mass and get an organic friction plate. Darkside developments are your best bet.
If you can cope with the noise then its up to you..
Offline Rhyso
« Reply #4 on: 27 November 2012, 13:05 »
Equally the G60 combo WILL NOT FIT the 130 TDI  :rolleyes: it has a 6 speed box
Unless you are going silly power then a standard clutch will be fine but equally its lifespan will depend on how the map delivers the power and your driving style  :smiley:
Offline sharmalini
« Reply #5 on: 27 November 2012, 14:01 »
Thanks for the advice. It was mainly more to do with the fact its not all the time i tay only do it for a couple of days and then not again for a few weeks?
Offline Dalo Harkin
« Reply #6 on: 27 November 2012, 14:34 »
does it happen at certain times? for example in 2nd or 3rd when you boot it, or is it random?
if its random then it probably is the clutch thats knackered
if its at certain points then itll be because of the map and may not be worth doing until it completely goes
Offline sharmalini
« Reply #7 on: 27 November 2012, 14:38 »
its mainly in the higher gears at mid revs when I drive it hard. But it will go weeks on end with no problems at all, thats the bit I cant work out.
Offline mcgee9t2
« Reply #8 on: 27 November 2012, 15:40 »
could just be that your map has a large power spike, and that when it gets to that spike the clutch cant handle the power and slips? and it only seems intermitent cause your not hitting those revs every day?
Offline sharmalini
« Reply #9 on: 27 November 2012, 15:55 »
possibly. When i say driven hard i dont mean flooring it and i can drive it the same way as when it slips and it will be fine. Guess I just need to resign myself its on the way out and start saving for the bumming i will get to replace it.
