Author Topic: welding and ecu  (Read 1361 times)
Offline raferackstraw
welding and ecu
« on: 26 November 2012, 19:37 »
hi guys i am having some extensive welding done and want to know if ecu should be unplugged as well as battery disconnected and any other precautions?
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline danny_p
Re: welding and ecu
« Reply #1 on: 26 November 2012, 23:41 »
depends on the type of welding
MIG you are generaly safe with  can get away without disconnecting anything.   (  unless you put eath clamp on stupid places like engine block ) keep it close and you should be fine, but i doing lots disconnecting the battery is allways a good idea.  if welding round eath points i will disconnect the ecu for piece of mind
MMA  / stick kwelding ,   really not a good idea to go near a car with one of these ...  disconnection of battery is a must as it';ll more thean likely have the reg pack out the alternator.
TIG    if useing scratch start it's as per MIG  if useing HF  anything with intergated circuits in is at risk discconect / remove the lot
all the VW's have gone bar 1.
Re: welding and ecu
« Reply #2 on: 27 November 2012, 07:03 »
thanks danny i'll ask when i see the guy
