Author Topic: Help needed with hoses please!  (Read 1345 times)
Offline solarized
« on: 18 July 2005, 15:05 »
Hi,
Got a dodgy idle / stalling problem when cold. Checked all the usual stuff - isv ect. On checking around for air leaks, I found a small hose that's pullin air in, and I aint sure where it goes. There's a small hose comes from the top of the fuel pressure regulator, connected to this is a t-piece, then the hose continues and connects to the inlet manifold. Another hose comes from the bottom of the t-piece, it's aroud 4 inches long, and it's just sat there pulling air in. Cant for the life of me see where it should be connected to - maybe it should just be plugged ? Anyone know ?
Judderi
Re: Help needed with hoses please!
« Reply #1 on: 18 July 2005, 15:10 »
What engine is it mate? 8v or 16?
Offline Mr Blue
« Reply #2 on: 18 July 2005, 15:15 »
if its the 8v then one of the hoses should go to the airbox from the 'T' connector. the little extra hose thats on the inlet should be sealed up.
it is on mine anyway
« Last Edit: 18 July 2005, 15:26 by Baby Blue Mk2 »
Offline solarized
« Reply #3 on: 18 July 2005, 15:22 »
Its a '88 8v by the way. Also it's had a K&N induction kit installed by previous owner, therefore no airbox.
Offline Mr Blue
« Reply #4 on: 18 July 2005, 15:27 »
seal it up. it wont hurt :wink:
Offline solarized
« Reply #5 on: 18 July 2005, 15:29 »
Yep, thats what I thought - just thought I'd check first - cheers.
Offline monzablue16v
« Reply #6 on: 18 July 2005, 23:19 »
That will have gone to the airbox vaccuum hose connectory bit :) like blue says get a screw and screw it in seals and can be undone when you discover where it goes :)
