Author Topic: 312 brake set up  (Read 1517 times)
Offline Mk2_tel
312 brake set up
« on: 26 November 2012, 16:16 »
Would the standard 15inch wheel fit
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: 312 brake set up
« Reply #1 on: 26 November 2012, 16:28 »
The standard wheel is 16" I think. I think it squeezes under 16s, not sure about 15s.  :undecided:
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #2 on: 26 November 2012, 16:31 »
fits under 16" steels,just! dont think it would fit 15's.
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline MC_PEA
« Reply #3 on: 26 November 2012, 16:35 »
My 350mm porsche set up could fit under 16" with abit of shaving so I would think 312mm would fit under 15"
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 26 November 2012, 16:57 »
312mm brakes do not fit beneath 15" rims. You need 16" minimum and even then you may need to shave the calipers slightly depending on the type of rim and offset.
Offline rockmonkey69
« Reply #5 on: 26 November 2012, 17:16 »
There must be a pubic hair's gap between the caliper and wheel  :shocked:
Your disks would be 13.8" and 16" wheels are less than 16" on the inner most of the band. Cutting it a bit close  :grin:
Offline MC_PEA
« Reply #6 on: 26 November 2012, 20:20 »
I'm not running them but i did manage to get 16" on them but there was about a mil gap between the caliper and the rim
Offline houston
« Reply #7 on: 26 November 2012, 20:25 »
the porsche caliper will be a lot thinner on the lip of the disc than the big cast vw item
« Reply #8 on: 26 November 2012, 23:56 »
312mm's need 16" or bigger even then some 16"'s are a tight fit.
Offline Big-G
« Reply #9 on: 27 November 2012, 20:07 »
Will 312's fit behind Montreal 2's ok ?
Gareth
My Build Thread (Ed38 sorry)
