Author Topic: Bushes question  (Read 1247 times)
Offline WeekendMechanic
  • Golf MK3 GTD
Bushes question
« on: 26 November 2012, 15:51 »
I`v decided to replace all my bushes for powerflex ones for the front i`m ok but for the rear i`m dubious are the ones in the link correct?
http://www.ebay.co.uk/itm/VW-Golf-Mk3-92-98-POWERFLEX-REAR-BEAM-AXLE-MOUNT-BUSHES-PFR85-206-PACK-OF-2-/170929192948?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27cc2c7ff4
They look nothing like the originals...
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Bushes question
« Reply #1 on: 26 November 2012, 16:08 »
Yes they are correct, the originals looks different as they are rubber inside a pressed metal casing, these powerflex ones are all rubber with just a metal sleeve on the inside. They don't require pressing in either like original ones they are just a push in fit.
  • Golf MK3 GTD
Re: Bushes question
« Reply #2 on: 26 November 2012, 16:31 »
Ok, Thank you.
So I have to take the axle off to push the originals out and press the new ones in?
« Last Edit: 26 November 2012, 16:37 by WeekendMechanic »
Offline Gti_Jamo
Re: Bushes question
« Reply #3 on: 26 November 2012, 16:56 »
Ideally yes, it can be done with it on but it a bit of a nightmare and you will need a special tool. Easiest way I done it was to remove the calipers then drop the axle. I set fire to the original bushes to burn out the rubber then using a hacksaw I cut a slit in the bush casings then they just chapped out with a chisel. Then just clean up the inner surface with some sand paper, bit of grease, then powerflex bushes just slot in place.
  • Golf MK3 GTD
Re: Bushes question
« Reply #4 on: 26 November 2012, 17:02 »
Cheers.
