Author Topic: Rebuilding mk4 90bhp engine, rebuild as 150?  (Read 3665 times)
Offline jonnyb
« on: 26 November 2012, 12:16 »
This might be a daft question, but here goes:
I've picked up a mk4 golf 1.9 tdi (90bhp) model.  It required a full engine rebuild to get back on the road, but i was wondering what are the differences between the 90 and 150bhp model?
Is it possible to upgrade a few parts to bridge the power gap?
If possible, would it require uprated gearbox/clutch or extra bits?.  (im assuming brakes would be a must).
Cheers in advance!
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Rebuilding mk4 90bhp engine, rebuild as 150?
« Reply #1 on: 26 November 2012, 21:21 »
Brakes, turbo, injectors, IC, gear box(6 speed), manifolds, piping. The list probably goes on...
Will cost an AWFUL lot of money to do that rebuild.  :lipsrsealed:
Offline scarr89
« Reply #2 on: 26 November 2012, 21:21 »
ECU and mapping. There is an easy £400+.
Offline danny_p
« Reply #3 on: 26 November 2012, 23:31 »
you chould in theory rebuild it as a 130 then get 150 or more with mapping,  but the 150 has quite a lot of differances so would be a twerp to build it as a 150 may as well just buy engine loom and ecu
all the VW's have gone bar 1.
Offline jonnyb
« Reply #4 on: 27 November 2012, 08:05 »
lol, seems like one big headache.  Like i said, it was just a thought.  Danny_p, you mention it may be possible to rebuild at 130?  What's involved?
Basically, im just trying to squeeze a bit more power out of the engine whilst im rebuilding, as i may as well take the opportunity.
Offline scarr89
« Reply #5 on: 27 November 2012, 22:01 »
All of the above mentioned...The only differences between a 150/130 is the turbo and the SMIC in the 130, FMIC for the 150.
Just the pipe work in the 130 is easier I guess.  :undecided:
Offline danny_p
« Reply #6 on: 27 November 2012, 22:25 »
thought there were ECU differances    allong with 130 turbo been traditional wastegate type and 150 been varible jobbie,  may be mistaken tho havent done much on dinkey diesels for a while now
Offline scarr89
« Reply #7 on: 28 November 2012, 05:40 »
ECUs are the same I believe, just mapped differently. Both turbo are VNT type  :smiley:
Offline jonnyb
« Reply #8 on: 28 November 2012, 12:48 »
Ok, so the 90bhp seems a lost cause regarding upgrading to a 130/150 somehow.
Much easier to take the remap option?  I'd be happy for now to have 110-120bhp
Offline scarr89
« Reply #9 on: 28 November 2012, 18:15 »
I would defo not re build as a 130/150.
The amount of effort time money would be ridonkulous!
