Author Topic: 12v portable battery booster recommendations? £100 budget.  (Read 1575 times)
Offline Mr Blue
Hi guys
Winter is here and I always have problems with a flat battery. My old cheap booster lasted a few months and the new budget is £100.
I need the highest crank amps within that budget and will be using it for the odd diesel engine.
A built in light, 12v socket or a tyre inflator would be a bonus.
Can anyone recommend one?
Blue  :smiley:
« Last Edit: 25 November 2012, 22:59 by Mr Blue »
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 12v portable battery booster recommendations? £100 budget.
« Reply #1 on: 25 November 2012, 23:49 »
Spend the money on a decent Bosch silver battery.
Disconnect all the extra switches you don't need..
Ahh - Forgot you you only have them for show...  :P
 :whistle:
For More Info Click To See;
Offline danny_p
« Reply #2 on: 26 November 2012, 00:11 »
there all crap at the end of the day.
crack the one you have open and fit a decent SLA battery   ignore the CCA they offer its all bollocks   mine clamed 900A
put the fluke meter clamp over the cabels and dead shoreted it with peack hold on the meter it did about 500 amps into a dead short    funny 900 A that. only did it as it really seemed lame compared to what it clamed  replacement was the same.
for work i now have an optima battery in a box  thats plugs into car/truck ( with chunky cabels for fast recharge )  and some 50mm leads pokeing out of said box with big crock clips on the ends  :smiley:
all the VW's have gone bar 1.
Offline Mr Blue
« Reply #3 on: 26 November 2012, 00:57 »
:grin: switches and looms ripped out Ken. Only seat elements and motors kept. Got a few month old bosch silver and its worse than my old halfords one.
Still need a booster for the other diesel motors.
Can't test the old one Danny as it doesnt hold charge but ill try that when i get one. Good tip!
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 26 November 2012, 10:12 »
Get a GOOD vehicle electrician on your car then!
If the battery's dying there's a problem with your electric which needs to be sorted.
Address the problem not the symptoms.
Offline Mr Blue
« Reply #5 on: 26 November 2012, 12:47 »
Car's are perfect! We have cars that are left parked up for a long time away from a power source. Jump starting them from another car is a pain.
Offline Egbutt Wash
« Reply #6 on: 26 November 2012, 16:20 »
30 seconds with a socket set or spanner and your negative battery terminal is removed.  That's what I do.
Currently digging a bunker.
  • Opinions я Us
« Reply #7 on: 26 November 2012, 17:41 »
Or get one of these:
http://www.langtoninfo.co.uk/showitem.aspx?isbn=0046221602234&loc=GBP
or an even better idea:
http://www.langtoninfo.co.uk/showitem.aspx?isbn=0839290004135&loc=GBP
Although I'd still contend you have an electrical issue with your car if you need a battery charger on it in a few months of putting a new battery into it.
Offline Martz
« Reply #8 on: 26 November 2012, 17:54 »
I have the solar trickle charger and it seems good enough.
