Author Topic: various electrical niggles all at th same time  (Read 1426 times)
Offline robjackson
« on: 25 November 2012, 17:26 »
Hi guys, iv been dubbin' and modding other motors for years now and would still consider myself as an amateur, (no longer a novice)
This query might sound simple and obvious, but i thought i'd run it by you lot before i go rummaging about and make the problem worse, or break smthing else.
Recently, all in a week, or even over a couple of days,
my rear fogs are on and wont go off, (also the orange light is on indicating that theyr on)
My f/n/s e/window wont go down,
My r/n/s door wont unlock when the others do, (almost evry time),
And the f/n/s side-light dosent wrk, (and hasnt the whole time i'v had her)
(Its a mk3 golf tdi estate btw. On an S-plate with vento front)
These are probly common probs, as iv had c/l & e/w issues on all my v-dubs
But can anyone shed any light please
(Havent looked at fuses yet as i thought these items probly dont share much in common)
« Last Edit: 25 November 2012, 17:42 by robjackson »
Offline raferackstraw
Re: various electrical niggles all at th same time
« Reply #1 on: 25 November 2012, 18:50 »
look at fuse then earthing points, the r/n/s and fog could have a common earth, front light check for 12v at plug but with a multimeter put red lead in each terminal and black lead to a good grounding point on chassis if you get 12v then earth return from plug is fubar.
check wiring to fog is sound
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
