Author Topic: Dashboard Problem  (Read 2255 times)
Offline adyspriggs
Dashboard Problem
« on: 23 November 2012, 12:56 »
 :sad:
i've got a problem with my dash.....
when i start the car everything is fine, after a couple of seconds all the gauges drop, rev counter, fuel,temp....
and now the dash backlights are inop
also the battery is draining so something is happening that shouldn't be
sometimes they come back on when cruising to a stop and the guages lights etc make it out as if the car is just starting!!
just took another look and when the car starts the guages are fine....once the led sets the mileage on the guages drop?
any ideas....
cheers
Ady
« Last Edit: 23 November 2012, 14:14 by adyspriggs »
Offline chrisford_vw
Re: Dashboard Problem
« Reply #1 on: 23 November 2012, 16:09 »
Mine did this got it scanned and the alternator was putting out to much current. Got a second hand one from Ebay for £15
Offline adyspriggs
« Reply #2 on: 23 November 2012, 16:13 »
Cheers for that i will have it looked at....at least its easy to get too :smiley:
Offline kempie
  • where would we be without duct tape?
« Reply #3 on: 23 November 2012, 18:36 »
just make sure the connection is ok to the guages first could be something simple
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 23 November 2012, 18:39 »
Yes as above check the 28 pin plug on the back first, it may have come adrift.
Offline adyspriggs
« Reply #5 on: 23 November 2012, 19:04 »
If you mean the plug on the back of the panel i have had this out today and it seems ok, is there anything specific in the engine compartment that may have come loose?
thanks for the suggestions so far its appreciated
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 23 November 2012, 20:27 »
You could drop your fuse box and give the wires a wiggle to see if they come on or drop out again,also pull off a battery teminal and put a meter across to see how much power is being drained,get someone to pull each fuse 1 at a time whilst watching the meter,it may pin point a prob.
