Author Topic: coolant sensor  (Read 1228 times)
Offline nu99et18
coolant sensor
« on: 22 November 2012, 22:28 »
Hi, have a 1.8t aum in my mk2 with oem loom/ecu and mk2 clocks, my problem is that the engine temperature over reads, the needle goes straight to the middle once started and once warm it looks like its constantly overheating which it isnt, i have done some research into it but cannot get a definate answer, the most convincing seems to be that i can fit a mk3 abf coolant sensor which should work with the mk2 clocks and the aum ecu. Is this true?
Offline Jimmyrallye
  • 20vt goodness
Re: coolant sensor
« Reply #1 on: 22 November 2012, 22:43 »
Mine is sort of the same but ive got a agu engine in mine ... My fans kick in about 3/4 of the tempature gauge but does start from the start from the begining at works it way up
