Author Topic: big puddle  (Read 1895 times)
Offline djmagpie
big puddle
« on: 22 November 2012, 21:48 »
just ad to drive throu a massive puddle and i got one ov thoses ebay cold feed filters on and i think its sucked up some water i drove thro it as slow as possible  car is now now jolting like mad is my valve stem going bend now (engine fked) wat shall i do now ??
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline Ant1981
  • Feed me, prod me
Re: big puddle
« Reply #1 on: 22 November 2012, 22:04 »
Sounds like the water may have made its way in far enough, possibly washing the big end bearing grease out. Possibly will need a big rebuild  :undecided:
If the brake discs have any rust on them tomorrow, then it's even worse.
« Last Edit: 22 November 2012, 22:07 by Ant1981 »
'09 Kawasaki Ninja ZX-6R
Offline dom
  • Back in a Mk4
Re: big puddle
« Reply #2 on: 22 November 2012, 22:14 »
Agreed, my guess it'll be so seized by tomorrow that it won't even turn over. It'd be worth whipping the head off straight away :wink:
Offline djmagpie
Re: big puddle
« Reply #3 on: 22 November 2012, 22:15 »
just took it up the road and seems fine now so a bit confuzzed ..wat u rekon wip the plugs out and change the oil ???just b on the safe side cheers
Offline dom
  • Back in a Mk4
Re: big puddle
« Reply #4 on: 22 November 2012, 22:18 »
How do the brakes look?
Offline djmagpie
Re: big puddle
« Reply #5 on: 22 November 2012, 22:22 »
fine and fill fine.. would i notice something with the brakes??
Offline james2
  • No scammers please.
Re: big puddle
« Reply #6 on: 22 November 2012, 22:42 »
just disconnect the bottom intercooler pipe see what comes out, i did the same.  :laugh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline djmagpie
Re: big puddle
« Reply #7 on: 22 November 2012, 22:45 »
cheers ill do it 2mozz
