Golf mk2
Heater problems
Topic: Heater problems (Read 1889 times)
Blue MK2
Guest
Heater problems
07 October 2003, 23:03 »
When i switch my heater on it dont work, sometimes it just holds on and sometimes it cuts off. Its got a mind of its own but it does blow out heat.
When i go over a bump it turns back on. Possibly a loose connection but where?
Any ideas? thanx
Gambit
Forum addict
Re:Heater problems
08 October 2003, 09:03 »
check the actual blower setting connections, (it just pulls apart.
then check the blower itself which is located behind the passenger parcel shelf
golfvr6
Guest
Re:Heater problems
08 October 2003, 18:53 »
Probably a problem with the blower itself. Check for loose connections.
Blue MK2
Guest
Re:Heater problems
09 October 2003, 18:05 »
I pulled out the connections and re fitted them to the blower. I havnt put the blower to the test yet but i found 2 other wires which looked disconnected.
I think one was a brown/yellow wire and the other was a
red/yellow one.
Are these wires pulled out from somewhere or is this normal?
Golf mk2
Heater problems
