Author Topic: Overheated  (Read 1803 times)
Offline FlashRedThree
  • MK III Flash Red 1.4 SE + MK V DBP 2.0T GTI
Overheated
« on: 21 November 2012, 17:28 »
Good evening,
Looking for a little advice on something. My car recently overheated in traffic due to a faulty fan switch.
It got to around 110 degrees, not sure how long for as I didn't notice straight away. I now have the dreaded mayo under the filler cap, indicating an internal coolant leak. However, there is none on the dipstick. The car has also developed a habit of losing 200 rpm from time to time when up to temperature at idle. Is it the head gasket, or should I be checking other things?
It's an AEX if this helps.
Thanks
Offline tweed
Re: Overheated
« Reply #1 on: 21 November 2012, 17:58 »
When was the last time you looked under the oil cap?
Mayo on that engine is common. 110 is high but I wouldn't worry just yet.
How long has the idle done that? Could be a sensor problem.
Re: Overheated
« Reply #2 on: 21 November 2012, 18:35 »
When I changed the oil in August. There was definitely none then! Could be the cold or something? Rpm dropped shorty after the overheat, made me wonder if it was an occasional loss of compression due to a mild gasket leak or something...
Thanks
Offline itavaltalainen
Re: Overheated
« Reply #3 on: 21 November 2012, 20:18 »
A small amount of mayo on filler cap is normal. It's a cold point on the engine, the reason you did not see is this in August is due to temperature... Short trips make this worse.
As for the high temp could be:
- faulty sensor (although that is usually rather complete failure or it "jumps" all over), can be tested with ohm meter (10£ multimeter from DIY shop will do, see attached photo for target values, sensor is in slightly different place on 1.4 and 1.6 blocks)
- thermostat, quite likely tbh, feel if both hoses are hot or bottom hose is at least very warm when it shows over 90 degrees. in this weather you'll have to drive 20 miles to properly get engine warm unless something is faulty.
- blocked radiator, same for diagnosis as thermostat (or takes hose off and see if water comes out the bottom if you pour it in the top)
- impeller has separated from shaft in the water pump, if it's this means you need a new one (plus cam belt, tensioner, etc)
and well, could be head gasket.... but would first go through others unless it's spitting with white smoke and goes through coolant as fast as petrol....
