Author Topic: AWX turbo fit?  (Read 3024 times)
Offline JackM92
AWX turbo fit?
« on: 20 November 2012, 22:59 »
I have a PD115 but its got mostly 130 parts on it including the turbo, I have been offered a good AWX 130 turbo are all the 130 turbo's the same or do they differ, Hoping its just a straight fit.
Also how much do you think I will be looking at fitting at a garage? Couple of hours labour?
Thanks
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: AWX turbo fit?
« Reply #1 on: 21 November 2012, 07:02 »
What is an AWX? An engine code from a different mk4 diesel? What type engine is it from?
Offline EsSeX dAn
Re: AWX turbo fit?
« Reply #2 on: 21 November 2012, 08:50 »
i will physically fit if its one with the manifold and turbo being one single unit. youll want the pd130 air intake pipe, the reducer for it and the red turbo outlet pipe. you might also need the pd130 pancake pipe too to connect the red pipe to the intercooler. as for labour its a fiddly little job as theyre arkward to get to so id say a few hours. hope that helps
i think i love you.....
Offline JackM92
Re: AWX turbo fit?
« Reply #3 on: 23 November 2012, 14:40 »
I believe its an engine code, From a passat sport pd130 apparently.
Rang my local VW specialist who i always use and they have quoted £180 + VAT for the turbo to be fitted and a 80k service as its due in 700miles.
Offline brayson
Re: AWX turbo fit?
« Reply #4 on: 10 December 2012, 14:32 »
Yep its a passat 1.9 130 engine code :)
Offline Chris.
Re: AWX turbo fit?
« Reply #5 on: 11 December 2012, 00:34 »
Also from a Audi A4 2003 area/shape....B8 models.
Doubt it would fit a golf due to engine being mounted the wrong way.....longitudinal in audi/passat vs trnasverse in mk4s.
Click For Build Thread
