Author Topic: Guys need a bit of advice  (Read 4782 times)
Offline p3asa
Re: Guys need a bit of advice
« Reply #10 on: 20 November 2012, 20:17 »
Where is the head and brick wall emotican  :grin:
You missed the bit "Try another dealer"
Offline arj7
« Reply #11 on: 20 November 2012, 20:26 »
My bad!
Yeah I could do, but wont they just do checks on the car and be like the car was not fitted with this originally or do you not think so?
Carbon Grey, 2012 GTD!!!!!!
Offline Schuey
« Reply #12 on: 20 November 2012, 20:44 »
Ok from what I know it's a version c manufactured in 2011.
The problem was it was running a lower firmware than it should have been originally, now it's running a 2660.
I'm worried about bricking it, and it maybe the unit is faulty I'm not sure.
Spoke to VW they go £2,000!
VW said they would charge me £60 to try a firmware update no guarantee that will work though, I don't want to spend money on repairs if they don't know how to fix it or if the unit is faulty.
Original owner is going to say not his problem I suspect when I get in touch.
If the unit is 2011 is it not covered by a 3 yr warranty?
Offline arj7
« Reply #13 on: 20 November 2012, 20:52 »
I doubt it most likely be 12 months at best.
Offline ajmoir36
« Reply #14 on: 20 November 2012, 21:15 »
I would work my way up one MDI firmware update at a time, testing to see if it solves any issues at each update, once its solved don't bother updating anymore. Thats what I did fortunatly it solved the "Cant remember where I left off with the hard drive on USB" on the first update. So I left it there.  If someone has a VCDS that can scan the car for you it will tell you the firmware version of the MDI.
What year is the car? as the chances are the MDI's never been updated?
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline arj7
« Reply #15 on: 20 November 2012, 21:18 »
Which MDI firmware should I start with then?
Offline ajmoir36
« Reply #16 on: 20 November 2012, 21:30 »
Anyone with a VCDS nearby? maybe? at least its a good start, I see its a 2012 GTD what month was it registered/built? i.e. the http://www.my-gti.com/category/in-car-entertainment/mdi gives you an idea on date.
Offline ajmoir36
« Reply #17 on: 20 November 2012, 21:32 »
Offline arj7
« Reply #18 on: 20 November 2012, 21:58 »
Its been retrofitted by previous owner, see the first few posts.
I contacted like 6-7 off this forum no one replied :(
« Last Edit: 20 November 2012, 22:05 by arj7 »
Offline p3asa
« Reply #19 on: 20 November 2012, 22:46 »
My bad!
That is why I said mine was retrofitted and they updated mine. Its just your luck but there is nothing to stop you trying a few dealers.
If you are going to the dealers with some other work then they are more than likely to try and sort it for you.
