Author Topic: Hazard Switch - Dash Lights - And a few other points!  (Read 1680 times)
Offline CriticalPoint
  • 1.8GTI Wolfberg Edition
« on: 19 November 2012, 15:19 »
 :laugh:
« Last Edit: 19 August 2013, 15:00 by CriticalPoint »
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Hazard Switch - Dash Lights - And a few other points!
« Reply #1 on: 19 November 2012, 17:13 »
Hi,
Steam sounds like the heater matrix has gone pop.. Do you get any HOT air??
Electrics - Hummm I would be checking the back of the fusebox, relays and fuse's to make sure that you haven't got a water issue with it being stood for so long...
Check the Tech secion at the op of the page and then the Fusebox FAQ's - section on CE1 seems relevant for your car!
HTH
For More Info Click To See;
Offline Steve_B
« Reply #2 on: 19 November 2012, 19:58 »
There's an earth point in front of the driver's door, kinda above the fusebox, and also a multi point one above the fusebox underneath the clocks. I'd check those if the previous owner was messing around with electrics.
« Reply #3 on: 21 November 2012, 15:21 »
Thank you both, Steve_B & X4MGS - This is what's been said to me earlier today also. Looking forwards to getting her road worthy, everything after that is just details - But if I can legally move her around, that'll make it so much easier to sort her in the long run. That's me for the rest of the week now - I'll hide myself away in the car with a work-light tonight and get to work! I'll post back when I know more. I've since bought cable, and sparks here is going to re-cable the lot. Shocking how shoddy the original job was, honestly. Not even the correct gauges of cable.. Makes me :sick:
Best, Crit
« Reply #4 on: 28 November 2012, 15:49 »
Update - Heater matrix popped, coolant filled the car, electrics no better, but I have dropped her off with a VW specialist (Autotechnic) in Oxford, and now due to flooding of the city, can't bloody get to her! Grueler.
Anyhu, see how she is when the roads stop being rivers!
