Author Topic: Broken l-line OBD port  (Read 1338 times)
Offline jparry
« on: 17 July 2005, 16:33 »
My diagnostics port is not working the k-line has about 9 volt on it but the l-line has nothing. I checked for continuity from the diag port to the ecu the k-line was fine this went to pin43 on the ecu plug there was about 10 kohm to ground is this right? there was no connection to the ecu plug from the l-line. Does anyone know what pin the l-line goes to on the ecu plug?
what voltage do people get on the k-line(pin7 OBD port) and l-line(pin15 OBD port)?
Cheers for any help. I dont realy want to have to bring it to a garage, too costly!!!!
Offline mk1
Re: Broken l-line OBD port
« Reply #1 on: 22 July 2005, 09:33 »
Hi, what car and what engine code is it?.
Steve.
