Golf mk3
hardmonkeys
Sunroof help
Topic: Sunroof help (Read 996 times)
Danny171
Sunroof help
18 November 2012, 11:57 »
Is the sunroof on a mk3 meant to open all the way?
I press one button and it raises at the rear, the middle button closes it, then the back button just drops it about 10mm, then nothing?
:cry:it's doing my head in
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Sunroof help
18 November 2012, 12:16 »
It should go back all the way.
My guess is that sliding rails are jammed up, more likely broken.
Danny171
Re: Sunroof help
18 November 2012, 12:25 »
Does that mean the head lining needs to be removed??
itavaltalainen
Re: Sunroof help
18 November 2012, 12:44 »
Yep.... unfortunately lining needs to come off so you can access sunroof frame, rails are in there.
Personally would first check if you can crank it back (carefully!) with the crank (take off where interior light is). Don't crank when it's solid, you don't want to end up with it being stuck open (not in this country anyway).
Danny171
Re: Sunroof help
18 November 2012, 13:27 »
Gutted, really didn't want to start messing with the roof lining.
When you say crank it open, do you mean with the Allen key that is supplied ?
sharki786
GOT BOOST??
Re: Sunroof help
18 November 2012, 14:06 »
allen key should be by the motor (just under that cover by the interior light)
if i was you i wouldnt bother as they get stuck & jam then you had it.
*****MK3 Anniversary*****
*****MK4 GTI T*****
BlackGT
Re: Sunroof help
Reply #6 on:
18 November 2012, 21:43 »
I replaced the sunroof on my Golf, and it's a surprisingly straightforward job (contrary to what the Haynes manual says), takes an hour or so but it's not difficult, just a lot of pieces of trim to remove.
Golf mk3
hardmonkeys
Sunroof help
