Author Topic: 1.8t electrics/clocks issue  (Read 9263 times)
Offline Screech16v
  • MK3 20vt AGU
Re: 1.8t electrics/clocks issue
« Reply #10 on: 18 November 2012, 20:28 »
Lol, it did feel like 4 months, i now have a steady oil light on all the time whilst running and no tacho ,thats it really,oh and my exhaust bangs abit at the rear,my oil light was flashing but i hadnt connected it.
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 20 November 2012, 19:00 »
Still stuck on the oil light and rev counter guys, HELP! I hate driving with oil warning on  :cry:
Offline CJA321
« Reply #12 on: 20 November 2012, 19:02 »
What pressure sensors did you use? Sure its not a sensor issue? That or wiring.
Offline Screech16v
  • MK3 20vt AGU
« Reply #13 on: 20 November 2012, 19:19 »
ive got both high and low sensors from the abf fitted,one is open curcuit and one is closed curcuit cant remember which is which,they b oth checkout as working
Offline ant_gti
  • mk3 20v turbo
« Reply #14 on: 20 November 2012, 22:34 »
did you use all 3 sensors from the abf?
Offline Screech16v
  • MK3 20vt AGU
« Reply #15 on: 20 November 2012, 23:11 »
Only using pressure switchs at the mo until i get the temp one rigged up,ive just been reading on another forum and its been said that the oil light can flash if the rev counter is not working,so to rule this out ,how do i get the rev counter to function as i believe (dont quote me on this) it takes  the engine speed signal from the coil,so what do i do as i dont have a coil anymore.  :undecided:
Offline CJA321
« Reply #16 on: 20 November 2012, 23:23 »
My speed sensor is on the box iirc. And im running an ABF box.
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 21 November 2012, 14:32 »
Is this the same sensor for the speedo then (3 pin connector)  as i have this fitted to my abf box also and my speedo works
Offline Screech16v
  • MK3 20vt AGU
« Reply #18 on: 21 November 2012, 18:24 »
Ive been told that the tacho gets its signal from the abf ecu,how will i make it work with the agu ecu if this is the case?
Offline CJA321
« Reply #19 on: 21 November 2012, 18:35 »
I think you use a mk4 sensor. Im really not sure though tbh, because the box i got was Brads old box and was set yp for the conversion when i bought it. Was all plug and play
