Author Topic: MAF for red injectors  (Read 1693 times)
Offline MC_PEA
« on: 16 November 2012, 01:47 »
I'v got saab red injectors running at 4bar what maf do I need for it? i'v beening looking a vr6 ones but I just want to know if there are any better ones for the job
Offline Toby
  • Car - less
Re: MAF for red injectors
« Reply #1 on: 16 November 2012, 07:54 »
U only use the housing! Not the sensor
Currently down under
Offline Prawny
  • R-tech power!!!
« Reply #2 on: 16 November 2012, 10:48 »
when you say they're running at 4 bar, do you mean they are currently, with a stock maf, or they will be when it's mapped?
if the car is currently mapped to a setup, and change on MAF or injectors will require a new map.
I would question why you're running a 4 bar though? unless you're running a turbo that takes the red tops right to their limit on 3 bar?
4 bar FPR's are generally bad news, as they put much more load on the pump. Avoid unless needed.
Offline Toby
  • Car - less
« Reply #3 on: 16 November 2012, 12:09 »
Saab reds, vr6 maf and 3 bar fpr was fine for my ko4 agu, 309bhp
Offline Chris.
« Reply #4 on: 16 November 2012, 16:28 »
VR6 maf housing is roughly 30% bigger.....so that gives an effective airflow of 241g/s at the limits of the SENSOR (based on 186g/s - cant remember if i was slightly higher)
241 g/s is 301bhp roughly.
Click For Build Thread
Offline AaronGS
« Reply #5 on: 16 November 2012, 16:55 »
What toby said.
i ran a true 3" MAF but had an uprated fuel pump to suit. That was running 440cc injectors at 3.5bar FRP iirc.
Offline Prawny
  • R-tech power!!!
« Reply #6 on: 16 November 2012, 20:26 »
Vr6 housing is 38% larger, agu sensor is maxed at 187g/s, so an agu sensor in a vr6 housing reading 187g/s is equivalent to 258 g/s, around 320bhp.
It ties in too, on the dyno last weekend I saw 307bhp with a maf peak of 176g/s. on the road I see 186-186g/s so around 320bhp at the limits of the sensor.
Offline Toby
  • Car - less
« Reply #7 on: 16 November 2012, 23:10 »
Your in the wrong job nick!  :evil:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 16 November 2012, 23:15 »
He was giving me the same pearls of wisdom earlier lol
Offline Chris.
« Reply #9 on: 17 November 2012, 02:47 »
Me and Nick worked out its 28% larger...
http://www.golfgtiforum.co.uk/index.php?topic=159756.msg1948535#msg1948535
So you must have 3" MAF ID which is 36% larger?
