Author Topic: Speedo foils  (Read 1096 times)
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
Speedo foils
« on: 14 November 2012, 22:58 »
Hi i have found some anni speedo foils was just wondering how hard they are to put in.if not too hard i might buy them.cheers
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
Offline SI74
Re: Speedo foils
« Reply #1 on: 14 November 2012, 23:21 »
Remove your steering wheel, remove the cover along the bottom, remove the two screws, pull the clocks out, remove the screws in the back of it, then pull the plastic face of, now take your time at this bit and make sure you remember where the needles are at pull them off remove the foils. Then reverse it to put them back in.
I think that's the most of it should give you idea.
Offline paulhgti
Re: Speedo foils
« Reply #2 on: 14 November 2012, 23:23 »
Cheers mate i thought it would be something like that
Offline damien010685
Re: Speedo foils
« Reply #3 on: 15 November 2012, 01:46 »
 I have never needed to remove the steering wheel to get the clocks out  :huh:
Offline Chris#101
Re: Speedo foils
« Reply #4 on: 15 November 2012, 07:28 »
Got a link to the anniversary foils?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline paulhgti
Re: Speedo foils
« Reply #5 on: 15 November 2012, 08:43 »
Offline BarryMKIV
Re: Speedo foils
« Reply #6 on: 15 November 2012, 09:06 »
Removing your steering wheel would probably make it easier, but you can take the clocks out without removing it. Set it to it's lowest setting, and pull it towards you as far as it goes, to give you a bit of extra room.
25th Anniversary GTI 1.8T No. 0441
