Author Topic: struggling to select gear , VR6  (Read 2653 times)
Offline JamesS
Re: struggling to select gear , VR6
« Reply #10 on: 05 December 2012, 15:47 »
You could probably do it without removing the lower dash but if it's anything like a mk2 (4/5 screws) only takes 1 min then it's out the way. Clutch master usually unbolts from the inside, you will have to unclip the push rod from the pedal box but it's all straight forward when you get down there.  :wink:
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline Diluxe
« Reply #11 on: 09 December 2012, 19:34 »
well swapped the master and the slave , and made no change.
any other suggestions?
1997 16V
Offline Leon27
« Reply #12 on: 09 December 2012, 20:08 »
As you've changed the master and slave I'd bleed the brakes first then have a go at the slave cylinder if you haven't already.
Are you using the pedal to bleed it? If so try a pressure bleeder. Slave cyls can be a pain especially when the system has been opened like yours has.
Offline Diluxe
« Reply #13 on: 09 December 2012, 20:37 »
I didn't think that the brake system and the gearbox were linked other than the reservoir , just wondering the need to bleed the brakes?
Thanks
« Last Edit: 09 December 2012, 21:11 by Diluxe »
1997 16V
