Author Topic: 60mm spring caps.  (Read 1474 times)
Offline mk3brick
60mm spring caps.
« on: 14 November 2012, 20:48 »
Hey you beautiful people, do any of you guys know the part number for the 60mm spring caps for a 96/7 golf.
« Last Edit: 16 November 2012, 10:23 by mk3brick »
Offline mk3brick
Re: 60mm spring caps.
« Reply #1 on: 16 November 2012, 10:23 »
anyone???
Offline tweed
« Reply #2 on: 16 November 2012, 16:04 »
Don't know what your going on about?
Offline Callum_K
« Reply #3 on: 16 November 2012, 16:32 »
Try ringing a VW dealer....
Failing that I have some FK 10mm lowering spring caps for sale, brand new. :P
Offline mk3brick
« Reply #4 on: 19 November 2012, 09:17 »
from what i understand there are two different diameters of spring caps on the mk3 golf 60mm wide and 80mm wide for different year golfs. i need the 60mm wide ones as i have a later mk3 that has a bigger centre bore for the strut shaft to sit through. just thought id ask you guys. cheers anyway
« Last Edit: 19 November 2012, 09:44 by mk3brick »
Offline mk3brick
« Reply #5 on: 19 November 2012, 09:19 »
cheers for the offer mate, but i want genuine non lowering spring caps. looks like ill be calling the stealership, just thought id ask here first. cheers
